This section provides procedures that you might need to configure IPv6 nodes on your network.
The term node in this context refers either to a Solaris server or client host.
Task |
Description |
For Instructions |
Enable IPv6 on a node |
Involves touching hostname6.interface file, displaying addresses, and entering the addresses in the /etc/inet/ipnodes file. See the note that follows this table. | |
Configure a Solaris IPv6 router |
Involves adding entries to the indp.conf file. | |
Configure a 6to4 router |
Involves configuring a 6to4 interface in the /etc/hostname6.ip.6to4tun0 file | |
Add IPv6 addresses to NIS and NIS+ |
Involves adding entries to the /etc/ipnodes file. | |
Add IPv6 addresses to DNS |
Involves adding AAAA records to the DNS zone and reverse zone file. |
You can enable IPv6 on a system when you install the Solaris software. If you answered yes to enable IPv6 during the installation process, you can omit the following procedures to enable IPv6.
Become superuser on the system where you want to enable IPv6.
Type the following for each interface.
# touch /etc/hostname6.interface |
Interface |
Interface name, such as le0, le1. |
Reboot the node
The reboot process sends router discovery packets. The router responds with a prefix. The response enables the node to configure the interfaces with an IPv6 address. Rebooting also restarts key network daemons in IPv6 mode.
Display the IPv6 addresses of all interfaces.
# ifconfig -a6 |
To show both IPv4 and IPv6 addresses, just use the -a option.
Add the IPv6 address to the appropriate name service as follows:
For NIS and NIS+, see How to Add IPv6 Addresses to NIS and NIS+.
For DNS, see How to Add IPv6 Addresses to DNS.
Become superuser on the system to become the router.
Edit the file /etc/inet/ndpd.conf with subnet prefixes by adding one or more of the following entries.
See the in.ndpd(1M) man page for a list of variables and allowable values. For more information about the ndpd.conf file, see the ndpd.conf(4) man page.
Add entries that specify router behavior for all interfaces.
ifdefault variable value |
Add entries that specify the default behavior of prefix advertisement.
prefixdefault variable value |
Add sets per interface parameter entries.
if interface variable value |
Add advertisements for each entry for interface prefix information.
prefix prefix/length interface variable value |
Reboot the system.
Neighbor discovery (in.ndpd) relays the subnet address prefixes of the hosts to the hosts. Also, the next generation RIP routing protocol (in.ripngd) runs automatically.
# Send router advertisements out all NICs ifdefault AdvSendAdvertisements on # Advertise a global prefix and a # site local prefix on three interfaces. # 0x9255 = 146.85 prefix 2:0:0:9255::0/64 hme0 prefix fec0:0:0:9255::0/64 hme0 # 0x9256 = 146.86 prefix 2:0:0:9256::0/64 hme1 prefix fec0:0:0:9256::0/64 hme1 # 0x9259 = 146.89 prefix 2:0:0:9259::0/64 hme2 prefix fec0:0:0:9259::0/64 hme2 |
Before you configure 6to4 routing on an IPv6 network, you must have done the following:
Configured IPv6 on all appropriate nodes at the prospective 6to4 site, as described in How to Enable IPv6 on a Node.
Selected at least one router with a connection to an IPv4 network to become the 6to4 router.
Configured a globally unique IPv4 address for the prospective 6to4 router's interface to the IPv4 network. The IPv4 address must be static. Do not use a dynamically allocated IPv4 address. For instructions for configuring an IPv4 interface, see “Network Configuration Procedures” in System Administration Guide: IP Services
Become superuser on the prospective 6to4 router.
Configure a 6to4 pseudo-interface on the router by creating the /etc/hostname6.ip.6to4tun0 file.
If you plan to use the recommended convention of subnet ID=0 and host ID=1, use the short format for /etc/hostname6.ip.6to4tun0:
tsrc IPv4 address up |
If you plan to use other conventions for subnet ID and host ID, use the long format for /etc/hostname6.ip.6to4tun0:
tsrc IPv4 address 2002:IPv4 address:subnet ID:host ID:/64 up |
The next table explains the parameters of /etc/hostname6.ip.6to4tun0 that are used in this step.
tsrc |
Indicates that this interface is used as a tunnel source |
IPv4 address |
Specifies, in dotted decimal format, the IPv4 address that is configured on the physical interface to become the 6to4 pseudo-interface |
2002 |
(Optional) Specifies the 6to4 prefix |
IPv4 address |
(Optional) Specifies, in hexadecimal, the IPv4 address of the pseudo-interface. |
subnet ID |
(Optional) Specifies, in hexadecimal notation, a subnet ID other than 0 |
host ID |
(Optional) Specifies a host ID other than 1 |
/64 |
Indicates that the address has a length of 64 bits. |
up |
Directs ifconfig to configure the interface as “up” |
Two IPv6 tunnels cannot have the same source and same destination addresses. Packets are dropped as a result. This type of event can happen if a 6to4 router also performs tunneling through atun.
(Optional) Create additional 6to4 pseudo-interfaces on the router.
Each prospective 6to4 pseudo-interface must have an already-configured, globally unique IPv4 address.
Run ifconfig to verify the status of the interface.
# ifconfig ip.6to4tun0 inet6 |
If the interface is correctly configured, you receive output that is similar to the following.
ip.6to4tun0: flags=2200041<UP,RUNNING,NONUD,IPv6>mtu 1480 index 11 inet tunnel src 129.146.87.188 tunnel hop limit 60 inet6 2002:8192:56bb:56bb::1/64 |
Edit /etc/inet/ndpd.conf to advertise 6to4 routing.
For detailed information, refer to ndpd.conf(4).
Specify the subnet to receive the advertisement in the first line.
Create an if entry with the following format:
if subnet-interface AdvSendAdvertisements 1 |
For example, to advertise 6to4 routing to the subnet that is connected to interface hme0, replace subnet-interface with hme0.
if hme0 AdvSendAdvertisements 1 |
Add the 6to4 prefix as the second line of the advertisement.
Create a prefix entry with following format:
prefix 2002:IPv4-address:subnet ID::/64 subnet-interface |
prefix 2002 |
Indicates a 6to4 prefix |
IPv4-address |
Specifies, in hexadecimal representation, the unique IPv4 address of the 6to4 pseudo-interface |
subnet ID |
Specifies, in hexadecimal, a subnet ID |
subnet-interface |
Router interface to which the subnet is connected |
Reboot the router.
Alternatively, you can issue a sighup to /etc/inet/in.ndpd to begin sending router advertisements.. The IPv6 nodes on each subnet to receive the 6to4 prefix now autoconfigure with new 6to4–derived addresses.
Add the new 6to4–derived addresses of the nodes to the name service that is used at the 6to4 site.
For instructions, go to How to Add IPv6 Addresses to DNS or How to Add IPv6 Addresses to NIS and NIS+.
For a multiple router site, the routers behind the 6to4 router might require further configuration to support 6to4. If your site uses RIP, you must configure on each non-6to4 router static routes to the 6to4 router. If you use a commercial routing protocol, you do not need to create static routes to the 6to4 router.
The following is an example of the short form of /etc/hostname6.ip.6to4tun0.
# cat /etc/hostname6.ip.6to4tun0 tsrc 129.146.87.188 up |
Here is an example of the long form of /etc/hostname6.ip.6to4tun0.
# cat /etc/hostname6.ip.6to4tun0 tsrc 129.146.87.188 2002:8192:56bb::1/64 up |
The following example shows output of ifconfig for a 6to4 pseudo-interface.
# ifconfig ip.6to4tun0 inet6 ip.6to4tun0: flags=2200041<UP,RUNNING,NONUD,IPv6> mtu 1480 index 11 inet tunnel src 129.146.87.188 tunnel hop limit 60 inet6 2002:8192:56bb::1/64 |
The next sample /etc/inet/ndpd.conf file advertises 6to4 routing on two subnets.
if qfe0 AdvSendAdvertisements 1 prefix 2002:8192:56bb:1::/64 qfe0 if qfe1 AdvSendAdvertisements 1 prefix 2002:8192:56bb:2::/64 qfe1 |
A new table has been added for NIS+ named ipnodes.org_dir. The table contains both IPv4 and IPv6 addresses for a host. The existing hosts.org_dir table, which contains only IPv4 addresses for a host, remains the same to facilitate existing applications. Both the hosts.org_dir and ipnodes.org_dir tables must be consistent with the IPv4 addresses. See IPv6 Extensions to Solaris Name Services for an overview.
Administration of the new ipnodes.org_dir table is similar to administering the hosts.org_dir. The same tools and utilities that are used to administer the previous NIS+ tables are valid for ipnodes.org_dir. See System Administration Guide: Naming and Directory Services for details on how to manipulate the NIS+ table.
The following command merges the entries from /etc/inet/ipnodes into the ipnodes.org_dir table, in verbose mode. The NIS+ table was probably created by nistbladm(1), nissetup(1M), or nisserver(1M).
On a command line, type the following command:
% nisaddent -mv -f /etc/inet/ipnodes ipnodes |
Use the following procedure to display the ipnodes.org_dir table.
% nisaddent -d ipnodes |
Two new maps have been added for NIS: ipnodes.byname and ipnodes.byaddr. These maps contain both IPv4 and IPv6 host name and address associations. The hosts.byname and hosts.byaddr maps, which contain only IPv4 host name and address associations, are unchanged so that they can facilitate existing applications. Administration of the new maps is similar to the maintenance of the hosts.byname and hosts.byaddr older maps. Again, it is important that when you update the hosts maps with IPv4 addresses that the new ipnode maps are also updated with the same information.
Tools that are aware of IPv6 use the new NIS maps and the new NIS+ tables.
Become superuser on the primary or secondary DNS server for your IPv6 network.
Edit the appropriate DNS zone file by adding AAAA records for each IPv6–enabled host, as follows.
host-name IN AAAA host-address |
Edit the DNS reverse zone file and add PTR records, using the following format.
host-address IN PTR host-name |
For detailed information on DNS administration, refer to “DNS Administration (Reference)” in System Administration Guide: Naming and Directory Services (DNS, NIS, and LDAP).
vallejo IN AAAA 2::9256:a00:20ff:fe12 IN AAAA fec0::9256:a00:20ff:fe12:528 |
$ORIGIN ip6.int. 8.2.5.0.2.1.e.f.f.f.9.2.0.0.a.0.6.5.2.9.0.0.0.0.0.0.0.0.2.0.0.0 \ IN PTR vallejo.Eng.apex.COM. 8.2.5.0.2.1.e.f.f.f.9.2.0.0.a.0.6.5.2.9.0.0.0.0.0.0.0.0.0.c.e.f \ IN PTR vallejo.Eng.apex.COM. |
