System Administration Guide: Naming and Directory Services (DNS, NIS, and LDAP)
Work Around
If the NIS slave server problem is not obvious, you can work around it while you debug using rcp or ftp to copy a recent version of the inconsistent map from any healthy NIS server. The following shows how to transfer the problem map.
ypslave# rcp ypmaster:/var/yp/mydomain/map.\* /var/yp/mydomain
The * character has been escaped in the command line, so that it will be expanded on ypmaster, instead of locally on ypslave.
