System Administration Guide: Oracle Solaris Containers-Resource Management and Oracle Solaris Zones
pset.min Property and pset.max Property Constraints
These two properties place limits on the number of processors that can be allocated to a processor set, both minimum and maximum. See Table 12–1 for more details about these properties.
Within these constraints, a resource partition's resources are available to be allocated to other resource partitions in the same Solaris instance. Access to the resource is obtained by binding to a pool that is associated with the resource set. Binding is performed at login or manually by an administrator who has the PRIV_SYS_RES_CONFIG privilege.
