System Administration Guide: Oracle Solaris Containers-Resource Management and Oracle Solaris Zones
IP Network Multipathing in Shared-IP Zones
IP network multipathing (IPMP) provides physical interface failure detection and transparent network access failover for a system with multiple interfaces on the same IP link. IPMP also provides load spreading of packets for systems with multiple interfaces.
All network configuration is done in the global zone. You can configure IPMP in the global zone, then extend the functionality to non-global zones. The functionality is extended by placing the zone's address in an IPMP group when you configure the zone. Then, if one of the interfaces in the global zone fails, the non-global zone addresses will migrate to another network interface card. A shared-IP zone can have multiple IP addresses, it can be part of multiple IPMP groups, and a given IPMP group can be used by multiple shared-IP zones.
In a given non-global zone, only the interfaces associated with the zone are visible through the ifconfig command.
See How to Extend IP Network Multipathing Functionality to Shared-IP Non-Global Zones. The zones configuration procedure is covered in How to Configure the Zone. For information on IPMP features, components, and usage, see Chapter 30, Introducing IPMP (Overview), in System Administration Guide: IP Services.
