Solaris Tunable Parameters Reference Manual
Parameters With No Functionality
The following section describes parameters whose functionality has been removed, but the parameter might still be available for compatibility reasons. These parameters are ignored if they are set.
Paging-Related Tunables
tune_t_gpgslo
Description
Obsolete. Variable left in place for compatibility reasons.
tune_t_minasmem
Description
System V Message Parameters
msgsys:msginfo_msgssz
Description
Specifies size of chunks system uses to manage space for message buffers. Obsolete since the Solaris 8 release.
Data Type
Signed integer
Default
40
Range
0 to MAXINT
Dynamic?
No. Loaded into msgtql field of msginfostructure.
Validation
The space consumed by the maximum number of data structures that would be created to support the messages and queues is compared to 25% of the available kernel memory at the time the module is loaded. If the number is too big, the message queue module refuses to load and the facility is unavailable. This computation does include the space that might be consumed by the messages. This situation occurs only when the module is first loaded.
When to Change
When the default value is not enough. Generally changed at the recommendation of software vendors.
Commitment Level
Obsolete
msgsys:msginfo_msgmap
Description
Number of messages the system supports. Obsolete since the Solaris 8 release.
Data Type
Signed integer
Default
100
Range
0 to MAXINT
Dynamic?
No
Validation
When to Change
Commitment Level
Obsolete
msgsys:msginfo_msgseg
Description
Number of msginfo_msgssz segments the system uses as a pool for available message memory. Total memory available for messages is msginfo_msgseg * msginfo_msgssz. Obsolete as of the Solaris 8 release.
Data Type
Signed short
Default
1024
Range
0 to 32,767
Dynamic?
No
Validation
The space consumed by the maximum number of data structures that would be created to support the messages and queues is compared to 25% of the available kernel memory at the time the module is loaded. If the number is too big, the message queue module refuses to load and the facility is unavailable. This computation does not include the space that might be consumed by the messages. This situation occurs only when the module is first loaded.
When to Change
Commitment Level
Obsolete
System V Semaphore Parameters
semsys:seminfo_semmap
Obsolete. Variable is present in kernel for compatibility reasons but is no longer used.
semsys:seminfo_semusz
Obsolete. Any values entered are ignored.
System V Shared Memory
shmsys:shminfo_shmmin
shmsys:shminfo_shmseg
NFS Module Parameters
nfs:nfs_32_time_ok
nfs:nfs_acl_cache
Obsolete as of the Solaris 2.6 release.
