Solaris Tunable Parameters Reference Manual
Preface
Solaris Tunable Parameter Reference Manual provides reference information about Solaris kernel and network tunable parameters. This manual does not provide tunable parameter information about the CDE or Java environments.
It contains information for both SPARC® based and IA based systems.
Note –
The SolarisTM operating environment is supported on two types of hardware, or platforms—SPARC and IA. The Solaris operating environment supports 64-bit and 32-bit address spaces. The information in this document pertains to both platforms and address spaces unless specified in a special chapter, section, note, bullet, figure, table, example, or code example.
Who Should Use This Book
This book is intended for experienced Solaris system administrators who might need to change kernel tunable parameters in certain situations. For guidelines on changing Solaris tunable parameters, refer to Tuning a Solaris System.
How This Book Is Organized
The following table describes the chapters in this book.
Chapter
Description
Chapter 1, Overview of Solaris System Tuning
An overview of tuning a Solaris system and a description of the format used in the book to describe the kernel tunables
Chapter 2, Solaris Kernel Tunables
A description of Solaris kernel tunables such as kernel memory, the file system, process size, and paging parameters
Chapter 3, NFS Tunable Parameters
A description of NFS tunables such as caching symbolic links, dynamic retransmission, and RPC security parameters
Chapter 4, TCP/IP Tunable Parameters
A description of TCP/IP tunables such as IP forwarding, source routing, and buffer sizing parameters
Chapter 5, Network Cache and Accelerator (NCA) Tunable Parameters
A description of tunable parameters for the Network Cache and Accelerator
Chapter 6, System Facility Parameters
A description of parameters for changing default values of certain system facilities by modifying files in the /etc/default directory
Appendix A, Tunable Parameter Change History
A history of parameters that have changed or are now obsolete
Appendix B, Revision History for this Manual
A history of this manual's revisions that includes the current Solaris release version
Related Books
The following books provide background material that might be useful when tuning Solaris systems.
Other Resources for Solaris Tuning Information
This table describes other resources for Solaris tuning information.
Tuning Resource
For More Information
Performance tuning classes
http://suned.sun.com
Online performance tuning information
http://www.sun.com/sun-on-net/performance
Ordering performance tuning documentation by Sun Microsystems Press
http://www.sun.com/books/blueprints.series.html
Typographic Conventions
The following table describes the typographic changes used in this book.
Table P–1 Typographic Conventions
Typeface or Symbol
Meaning
Example
AaBbCc123
 The names of commands, files, and directories; on-screen computer output
Edit your .login file.
Use ls -a to list all files.
machine_name% you have mail.
AaBbCc123
 What you type, contrasted with on-screen computer output
machine_name% su
Password:
AaBbCc123
 Command-line placeholder: replace with a real name or value
To delete a file, type rm filename.
AaBbCc123
Book titles, new words, or terms, or words to be emphasized.
Read Chapter 6 in User's Guide.
These are called class options.
You must be root to do this.
Shell Prompts in Command Examples
The following table shows the default system prompt and superuser prompt for the C shell, Bourne shell, and Korn shell.
Table P–2 Shell Prompts
Shell
Prompt
 C shell promptmachine_name%
 C shell superuser promptmachine_name#
 Bourne shell and Korn shell prompt$
 Bourne shell and Korn shell superuser prompt#
