Linker and Libraries Guide
Dependencies Between Unbundled Products
Another issue related to dependency location is how to establish a model whereby unbundled products express dependencies between themselves.
For example, the unbundled product XYZ might have dependencies on the product ABC. This dependency can be established by a host package installation script. This script generates a symbolic link to the installation point of the ABC product, as shown in the following figure.
Figure C–2 Unbundled Co-Dependencies
Unbundled co-dependencies example.
The binaries and shared objects of the XYZ product can represent their dependencies on the ABC product using the symbolic link. This link is now a stable reference point. For the application xyz, this runpath would be:
% dump -Lv xyz
  [1]    NEEDED  libX.so.1
  [2]    NEEDED  libA.so.1
  [3]    RUNPATH $ORIGIN/../lib:$ORIGIN/../ABC/lib
and similarly for the dependency libX.so.1 this runpath would be:
% dump -Lv libX.so.1
  [1]    NEEDED  libY.so.1
  [2]    NEEDED  libC.so.1
  [3]    RUNPATH $ORIGIN:$ORIGIN/../ABC/lib
If this product is now installed under /usr/local/XYZ, its post-install script would be required to establish a symbolic link of:
% ln -s ../ABC /usr/local/XYZ/ABC
If the user's PATH is augmented with /usr/local/XYZ/bin, then invocation of the application xyz result in a pathname lookup for its dependencies as follows:
% ldd -s xyz
  find object=libX.so.1; required by xyz
    search path=$ORIGIN/../lib:$ORIGIN/../ABC/lib  (RPATH from file xyz)
      trying path=/usr/local/XYZ/lib/libX.so.1
        libX.so.1 =>     /usr/local/XYZ/lib/libX.so.1
  find object=libA.so.1; required by xyz
      trying path=/usr/local/XYZ/lib/libA.so.1
      trying path=/usr/local/ABC/lib/libA.so.1
        libA.so.1 =>     /usr/local/ABC/lib/libA.so.1
  find object=libY.so.1; required by /usr/local/XYZ/lib/libX.so.1
     search path=$ORIGIN:$ORIGIN/../ABC/lib \
                (RPATH from file /usr/local/XYZ/lib/libX.so.1)
      trying path=/usr/local/XYZ/lib/libY.so.1
        libY.so.1 =>     /usr/local/XYZ/lib/libY.so.1
  find object=libC.so.1; required by /usr/local/XYZ/lib/libX.so.1
      trying path=/usr/local/XYZ/lib/libC.so.1
      trying path=/usr/local/ABC/lib/libC.so.1
        libC.so.1 =>     /usr/local/ABC/lib/libC.so.1
  find object=libB.so.1; required by /usr/local/ABC/lib/libA.so.1
     search path=$ORIGIN  (RPATH from file /usr/local/ABC/lib/libA.so.1)
       trying path=/usr/local/ABC/lib/libB.so.1
        libB.so.1 =>     /usr/local/ABC/lib/libB.so.1
