Solaris Volume Manager Administration Guide
RAID 1 Volume Options
The following options are available to optimize mirror performance:
You can define mirror options when you initially create the mirror, or after a mirror has been set up. For tasks related to changing these options, see How to Change RAID 1 Volume Options.
RAID 1 Volume Read and Write Policies
Solaris Volume Manager enables different read and write policies to be configured for a RAID 1 volume. Properly set read and write policies can improve performance for a given configuration.
Table 9–1 RAID 1 Volume Read Policies
Read Policy
Description
Round Robin (Default)
Attempts to balance the load across the submirrors. All reads are made in a round-robin order (one after another) from all submirrors in a mirror.
Geometric
Enables reads to be divided among submirrors on the basis of a logical disk block address. For instance, with a two-way submirror, the disk space on the mirror is divided into two equally-sized logical address ranges. Reads from one submirror are restricted to one half of the logical range, and reads from the other submirror are restricted to the other half. The geometric read policy effectively reduces the seek time necessary for reads. The performance gained by this mode depends on the system I/O load and the access patterns of the applications.
First
Directs all reads to the first submirror. This policy should be used only when the device or devices that comprise the first submirror are substantially faster than those of the second submirror.
Table 9–2 RAID 1 Volume Write Policies
Write Policy
Description
Parallel (Default)
A write to a mirror is replicated and dispatched to all of the submirrors simultaneously.
Serial
Performs writes to submirrors serially (that is, the first submirror write completes before the second is started). The serial option specifies that writes to one submirror must complete before the next submirror write is initiated. The serial option is provided in case a submirror becomes unreadable, for example, due to a power failure.
