With the metassist command, you can specify volume characteristics in terms of quality of service. You can specify the following quality of service characteristics:
size
redundancy (number of copies of data)
data paths
fault recovery (whether the volume should be associated with a hot spare pool)
volume types (for example, RAID 0 (concatenation) or RAID 0 (stripe))
components to use in specific volumes
components that are available or unavailable for use
number of components to use
details specific to the type of volume being created (including interlace value for stripes, read policy for mirrors, and similar characteristics)
