Solaris Volume Manager Administration Guide
Example—Creating a RAID 0 (Stripe) Volume of Two Slices With a 32–Kbyte Interlace Value
# metainit d10 1 2 c0t1d0s2 c0t2d0s2 -i 32k
d10: Concat/Stripe is setup
The stripe, d10, consists of a single stripe (the number 1) that is made of two slices (the number 2). The -i option sets the interlace value to 32 Kbytes. (The interlace value cannot be less than 8 Kbytes, nor greater than 100 Mbytes.) The system verifies that the volume has been set up.
