Solaris Volume Manager Administration Guide
Enabling a Component
You can enable a component when any of the following conditions exist:
Note –
Always check for state database replicas and hot spares on the drive being replaced. Any state database replica shown to be in error should be deleted before replacing the disk. Then after enabling the component, they should be re-created (at the same size). You should treat hot spares in the same manner.
