IPsec and IKE Administration Guide
Encryption Algorithms
Encryption algorithms encrypt data with a key. The algorithms operate on data in units of a block size. The man pages for encryption algorithms describe the block size and the key size for each algorithm. By default, the DES–CBC and 3DES-CBC algorithms are installed.
The AES and Blowfish algorithms are available to IPsec when you install the Solaris Encryption Kit. The kit is available on a separate CD that is not part of the Solaris 9 installation box. The Solaris 9 Encryption Kit Installation Guide describes how to install the Solaris Encryption Kit.
The following table lists the encryption algorithms that are supported in the Solaris operating environment. The table lists the format of the algorithms when the algorithms are used as security options to the IPsec utilities. The table also lists their man page names, and lists the package that contains the algorithm.
Table 1–2 Supported Encryption Algorithms
Algorithm Name
Security Option Format
Man Page
des, des-cbc
SUNWcsr, SUNWcarx.u
3DES–CBC or Triple-DES
3des, 3des-cbc
SUNWcsr, SUNWcarx.u
blowfish, blowfish-cbc
SUNWcryr, SUNWcryrx
aes, aes-cbc
SUNWcryr, SUNWcryrx
