Solaris 9 12/03 Installation Guide
Adding Files to the /etc/lu/synclist
Solaris Live Upgrade checks for critical files that have changed. If these files' content is not the same in both boot environments, they are copied from the active boot environment to the new boot environment. Synchronizing is meant for critical files such as /etc/passwd or /etc/group files that might have changed since the new boot environment was created.
The /etc/lu/synclist file contains a list of directories and files that are synchronized. In some instances, you might want to copy other files from the active boot environment to the new boot environment. You can add directories and files to /etc/lu/synclist if necessary.
Adding files not listed in the /etc/lu/synclist could cause a system to become unbootable. The synchronization process only copies files and creates directories. The process does not remove files and directories.
The following example of the /etc/lu/synclist file shows the standard directories and files that are synchronized for this system.
/var/mail                    OVERWRITE
/var/spool/mqueue            OVERWRITE
/var/spool/cron/crontabs     OVERWRITE
/var/dhcp                    OVERWRITE
/etc/passwd                  OVERWRITE
/etc/shadow                  OVERWRITE
/etc/opasswd                 OVERWRITE
/etc/oshadow                 OVERWRITE
/etc/group                   OVERWRITE
/etc/pwhist                  OVERWRITE
/etc/default/passwd          OVERWRITE
/etc/dfs                     OVERWRITE
/var/log/syslog              APPEND
/var/adm/messages            APPEND
Examples of directories and files that might be appropriate to add to the synclist file are the following:
/var/yp                    OVERWRITE
/etc/mail                  OVERWRITE
/etc/resolv.conf           OVERWRITE
/etc/domainname            OVERWRITE
The synclist file entries can be files or directories. The second field is the method of updating that occurs on the activation of the boot environment. There are three methods for updating the files:
