Solaris 9 12/03 Installation Guide
Required Packages
Check your current operating environment for the packages in the following table, which are required to use Solaris Live Upgrade. If packages in the column for your release are missing, use the pkgadd command to add the packages.
Table 31–2 Required Packages for Solaris Live Upgrade
Solaris 2.6 Release
Solaris 7 Release
Solaris 8 Release
SUNWadmap
SUNWadmap
SUNWadmap
SUNWadmc
SUNWadmc
SUNWadmc
SUNWjvrt
SUNWjvrt
SUNWj2rt
SUNWlibC
SUNWlibC
SUNWlibC
SUNWadmfw
SUNWbzip
SUNWmfrun
SUNWloc
To check for packages on your system, type the following command.
% pkginfo [[package_name]]
