Solaris 9 12/03 Installation Guide
cluster Profile Keyword (Adding Software Groups)
cluster group_name
cluster designates the software group to add to the system. The group_name for each software group is listed in the following table.
Software Group
group_name
Core System Support Software Group
SUNWCreq
End User Solaris Software Group
SUNWCuser
Developer Solaris Software Group
SUNWCprog
Entire Solaris Software Group
SUNWCall
Entire Solaris Software Group Plus OEM Support
SUNWCXall
You can specify only one software group in a profile. The software group must be specified before other cluster and package entries. If you do not specify a software group with cluster in the profile, the end–user software group, SUNWCuser, is installed on the system.
