Solaris 9 12/03 Installation Guide
x86: fdisk Profile Keyword
fdisk disk_name type size
fdisk defines how the fdisk partitions are set up on an x86 based system. You can specify fdisk more than once. When fdisk partitions an x86 based system, the following occurs:
disk_name – Use the following values to specify where the fdisk partition is to be created or deleted:
type – Use the following values to specify the type of fdisk partition that is to be created or deleted on the specified disk:
The following table shows the integer and hexadecimal numbers for some of the fdisk types.
fdisk Type
DDD
HH
DOSOS12
1
01
PCIXOS
2
02
DOSOS16
4
04
EXTDOS
5
05
DOSHUGE
6
06
DOSDATA
86
56
OTHEROS
98
62
UNIXOS
99
63
size – Use one of the following values:
