Solaris 9 12/03 Installation Guide
locale Profile Keyword
locale locale_name
Note –
You can use locale with both the initial installation and upgrade options.
locale designates the locale packages you want to install or add when upgrading for the specified locale_name. The locale_name values are the same as those values that are used for the $LANG environment variable. Appendix D, Locale Values (Reference) contains a list of valid locale values.
When you use the local keyword, consider the following:
