Solaris 9 12/03 Installation Guide
Installing With a DHCP Server
If you configured a DHCP server to support WAN boot options, you can use the DHCP server to provide client configuration information during the installation. For more information about configuring a DHCP server to support a WAN boot installation, see (Optional) Providing Configuration Information With a DHCP Server.
This procedure makes the following assumptions.
To Install With a DHCP Server
  1. If the client system is currently running, bring the system to run level 0.
    # init 0
    The ok prompt is displayed.
  2. At the ok prompt on the client system, set the network boot argument variables in OBP.
    ok setenv network-boot-arguments dhcp,hostname=client-name
    Instructs the OBP to set the following boot arguments
    dhcp
    Instructs the OBP to use the DHCP server to configure the client
    Specifies the host name you want to assign to the client
  3. Boot the client from the network.
    ok boot net - install
    net - install
    Instructs the client to use the network boot argument variables to boot from the WAN
    The client installs over the WAN. If the WAN boot programs do not find all the necessary installation information, the wanboot program prompts to provide the missing information. Type the additional information at the prompt.
Example 41–7 WAN Boot Installation With a DHCP Server
In the following example, the DHCP server on the network provides client configuration information. This sample requests the host name myhost for the client.
hostname=myhost
Resetting ...
Sun Blade 100 (UltraSPARC-IIe), No Keyboard
Copyright 1998-2003 Sun Microsystems, Inc.  All rights reserved.
OpenBoot 4.x.build_28, 256 MB memory installed, Serial #50335475.
Ethernet address 0:3:ba:e:f3:75, Host ID: 83000ef3.
Rebooting with command: boot net - install
Boot device: /pci@1f,0/network@c,1  File and args: - install
