Solaris 9 12/03 Installation Guide
Using Digital Certificates for Server and Client Authentication
The WAN boot installation method can use PKCS#12 files to perform an installation over HTTPS with server or both client and server authentication. For requirements and guidelines about using PKCS#12 files, see Digital Certificate Requirements.
To use a PKCS#12 file in a WAN boot installation, you perform the following tasks.
The wanbootutil command provides options to perform the tasks in the previous list.
Before you split a PKCS#12 file, create the appropriate subdirectories of the /etc/netboot hierarchy on the WAN boot server.
Creating a Trusted Certificate and Client Private Key
  1. Assume the same user role as the web server user on the WAN boot server.
  2. Extract the trusted certificate from the PKCS#12 file. Insert the certificate in the client's truststore file in the /etc/netboot hierarchy.
    # wanbootutil p12split -i p12cert \
      -t /etc/netboot/net-ip/client-ID/truststore
    p12split
    Option to wanbootutil command that splits a PKCS#12 file into separate private key and certificate files.
    -i p12cert
    Specifies the name of the PKCS#12 file to split.
    Inserts the certificate in the client's truststore file. net-ip is the IP address of the client's subnet. client-ID can be a user-defined ID or the DHCP client ID.
  3. (Optional) Decide if you want to require client authentication.
    1. Insert the client certificate in the client's certstore.
      # wanbootutil p12split -i p12cert -c \
        /etc/netboot/net-ip/client-ID/certstore -k keyfile
      p12split
      -i p12cert
      -c /etc/netboot/net-ip/client-ID/certstore
      Inserts the client's certificate in the client's certstore. net-ip is the IP address of the client's subnet. client-ID can be a user-defined ID or the DHCP client ID.
      -k keyfile
      Specifies the name of the client's SSL private key file to create from the split PKCS#12 file.
    2. Insert the private key in the client's keystore.
      # wanbootutil keymgmt -i -k keyfile \
         -s /etc/netboot/net-ip/client-ID/keystore -o type=rsa
      keymgmt -i
      Inserts an SSL private key in the client's keystore
      -k keyfile
      Specifies the name of the client's private key file that was created in the previous step
      Specifies the path to the client's keystore
      -o type=rsa
      Specifies the key type as RSA
Example 40–2 Creating a Trusted Certificate for Server Authentication
In the following example, you use a PKCS#12 file to install client 010003BA152A42 on subnet 192.168.255.0. This command sample extracts a certificate from a PKCS#12 file that is named client.p12. The command then places the contents of the trusted certificate in the client's truststore file.
# wanbootutil p12split -i client.p12 \
   -t /etc/netboot/192.168.255.0/010003BA152A42/truststore
# chmod 600 /etc/netboot/192.168.255.0/010003BA152A42/truststore
