Solaris 9 12/03 Installation Guide
Performing a Noninteractive WAN Boot Installation
Use this installation method if you prefer to install keys and set client configuration information before you install the client. You can then boot the client from the WAN and perform an unattended installation.
This procedure assumes that you have either installed keys in the client's OBP, or that you are performing an insecure installation. For information about installing keys on the client before your installation, see Installing Keys on the Client.
To Perform a Noninteractive Installation
  1. If the client system is currently running, bring the system to run level 0.
    # init 0
    The ok prompt is displayed.
  2. At the ok prompt on the client system, set the network boot argument variables in OBP.
    ok setenv network-boot-arguments
    host-ip=client-IP,router-ip=router-ip,
    subnet-mask=mask-value,hostname=client-name,
    http-proxy=proxy-ip:port,file=wanbootCGI-URL
    Note –
    The line breaks in this command sample are included for formatting purposes only. Do not enter a carriage return until you finish typing the command.
    Instructs the OBP to set the following boot arguments
    host-ip=client-IP
    Specifies the IP address of the client
    router-ip=router-ip
    Specifies the IP address of the network router
    Specifies the subnet mask value
    Specifies the host name of the client
    (Optional) http-proxy=proxy-ip:port
    Specifies the IP address and port of the network's proxy server
    file=wanbootCGI-URL
    Specifies the URL of the wanboot-cgi program on the web server
  3. Boot the client.
    ok boot net - install
    net - install
    Instructs the client to use the network boot argument variables to boot from the WAN
    The client installs over the WAN. If the WAN boot programs do not find all the necessary installation information, the wanboot program prompts to provide the missing information. Type the additional information at the prompt.
Example 41–5 Noninteractive WAN Boot Installation
In the following example, the network boot argument variables for the client system seahag are set before the machine is booted. This example assumes that a hashing key and encryption key are already installed on the client. For information about installing keys before you boot from the WAN, see Installing Keys on the Client.
ok setenv network-boot-arguments host-ip=192.168.198.136,
router-ip=192.168.198.129,subnet-mask=255.255.255.192,hostname=seahag,
file=http://192.168.198.135/cgi-bin/wanboot-cgi
Resetting ...
Sun Blade 100 (UltraSPARC-IIe), No Keyboard
Copyright 1998-2003 Sun Microsystems, Inc.  All rights reserved.
OpenBoot 4.x.build_28, 256 MB memory installed, Serial #50335475.
Ethernet address 0:3:ba:e:f3:75, Host ID: 83000ef3.
Rebooting with command: boot net - install
Boot device: /pci@1f,0/network@c,1  File and args: - install
The following variables are set.
