Solaris 9 12/03 Release Notes
SPARC: Veritas Volume Manager Might Fail on Systems Running Solaris 9 12/03 Software (4642114)
If you try to perform various tasks with Veritas Volume Manager on a system that is running the Solaris 9 12/03 software, the following utilities might produce a core dump:
Workaround: Follow these steps:
  1. Become superuser.
  2. Verify that the /var/ld/ld.config file and /usr/bin/crle utility exist on the system.
  3. Type the following commands in a terminal window:
     # /usr/bin/cp /var/ld/ld.config /var/ld/
     # /usr/bin/crle -E LD_LIBRARY_PATH=/usr/lib
     # appropriate-vxddladm-command
     # /usr/bin/mv /var/ld/ /var/ld/ld.config
