Solaris 9 12/03 Release Notes
Edit Config File Menu Item in Smartcards Management Console Does Not Work (4447632)
The Edit Config File menu item in the Smartcards Management Console does not edit smart card configuration files that are located in /etc/smartcard/opencard.properties. If the menu item is selected, a warning is displayed which indicates not to continue unless requested by technical support.
Workaround: Do not use the Edit Config File menu item in the Smartcards Management Console. For information on smart card configuration, see the Solaris Smartcard Administration Guide.
