In the Solaris 9 12/03 software and other systems based on UNIX, PDF documents on the Solaris 9 12/03 Documentation 1 of 2 CD are not accessible in the following European locales:
de (German)
es (Spanish)
fr (French)
it (Italian)
sv (Swedish)
This problem occurs because of a limitation with Adobe Acrobat Reader. For more information on this problem, see the Adobe Technote site at http://www.adobe.com:80/support/techdocs/294de.htm.
Workaround: Choose one of the following workarounds.
In the Solaris 9 12/03 software and other systems based on UNIX, set the environment variable LC_ALL to C acroread. For example, in the C shell, type the following command in a terminal window:
% env LC_ALL=C acroread |
For systems that are not based on UNIX, upgrade to Adobe Acrobat Reader 5.0 or a later version.
