System Administration Guide: Basic Administration
Specifying the Slice
The string that you use to identify a specific slice on a specific disk depends on the controller type, either direct or bus-oriented. The following table describes the different types of direct or bus-oriented controllers on different platforms.
Table 30–2 Controller Types
Direct controllers
Bus-Oriented Controllers
IDE (x86)
SCSI (SPARC/x86)
FCAL (SPARC)
ATA (SPARC/x86)
The conventions for both types of controllers are explained in the following subsections.
Note –
Controller numbers are assigned automatically at system initialization. The numbers are strictly logical and imply no direct mapping to physical controllers.
