System Administration Guide: Basic Administration
Displaying Partition Table Information
The following is an example of a partition table from a 4.0-Gbyte disk with a VTOC label displayed from the format utility:
Total disk cylinders available: 8892 + 2 (reserved cylinders)
Part      Tag    Flag     Cylinders        Size            Blocks
  0       root    wm    1110 - 4687        1.61GB    (0/3578/0) 3381210
  1       swap    wu       0 - 1109      512.00MB    (0/1110/0) 1048950
  2     backup    wm       0 - 8891        4.01GB    (0/8892/0) 8402940
  3 unassigned    wm       0               0         (0/0/0)          0
  4 unassigned    wm       0               0         (0/0/0)          0
  5 unassigned    wm       0               0         (0/0/0)          0
  6 unassigned    wm       0               0         (0/0/0)          0
  7       home    wm    4688 - 8891        1.89GB    (0/4204/0) 3972780
The partition table displayed by the format utility contains the following information:
Column Name
Description
Part
Partition (or slice number). See Table 32–7 for a description of this column.
Tag
Partition tag. See Table 32–7 for a description of this column.
Flags
Partition flag. See Table 32–7 for a description of this column.
Cylinders
The starting and ending cylinder number for the slice.
Size
The slice size in Mbytes.
Blocks
The total number of cylinders and the total number of sectors per slice in the far right column.
First Sector
EFI – The starting block number.
Last Sector
EFI – The ending block number.
The following is an example of a EFI disk label displayed by using the prtvtoc command.
# prtvtoc /dev/rdsk/c4t1d0s0
* /dev/rdsk/c4t1d0s0 partition map
* Dimensions:
*     512 bytes/sector
* 2576941056 sectors
* 2576940989 accessible sectors
* Flags:
*   1: unmountable
*  10: read-only
*                           First     Sector    Last
* Partition  Tag  Flags     Sector     Count    Sector   Mount Directory
       0      2    00          34   629145600  629145633
       1      4    00   629145634   629145600 1258291233
       6      4    00  1258291234  1318633404 2576924637
       8     11    00  2576924638       16384 2576941021
* Flags:
*   1: unmountable
*  10: read-only
The prtvtoc command provides the following information:
Column Name
Description
Dimensions
This section describes the physical dimensions of the disk drive.
Flags
This section describes the flags listed in the partition table section. For a description of partition flags, see Table 32–7.
Partition (or Slice) Table
This section contains the following information:
Partition
Partition (or slice number). For a description of this column, see Table 32–7.
Tag
Partition tag. For a description of this column, see Table 32–7.
Flags
Partition flag. For a description of this column, see Table 32–7.
First Sector
The first sector of the slice.
Sector Count
The total number of sectors in the slice.
Last Sector
The last sector of the slice.
Mount Directory
The last mount point directory for the file system.
