System Administration Guide: Basic Administration
Managing Disks With EFI Disks Labels
Use the following table to locate information on managing disks with EFI disk labels.
Task
For More Information
If the system is already installed, connect the disk to the system and perform a reconfiguration boot.
SPARC: Adding a System Disk or a Secondary Disk (Task Map)
Repartition the disk with the format utility, if necessary.
SPARC: How to Create Disk Slices and Label a Disk
Create disk volumes, and if needed, create soft partitions with Solaris Volume Manager.
“Storage Management Concepts” in Solaris Volume Manager Administration Guide
Create UFS file systems for the new disk with the newfs command.
SPARC: How to Create File Systems
Or, create a QFS file system.
http://docs.sun.com/db/coll/20445.2
