System Administration Guide: Basic Administration
The fsck Summary Message
When you run the fsck command interactively and it completes successfully, a message similar to the following is displayed:
# fsck /dev/rdsk/c0t0d0s7
** /dev/rdsk/c0t0d0s7
** Last Mounted on /export/home
** Phase 1 - Check Blocks and Sizes
** Phase 2 - Check Pathnames
** Phase 3 - Check Connectivity
** Phase 4 - Check Reference Counts
** Phase 5 - Check Cyl groups
2 files, 9 used, 2833540 free (20 frags, 354190 blocks, 0.0% fragmentation)
The last line of fsck output describes the following information about the file system:
# files
Number of inodes in use
# used
Number of fragments in use
# free
Number of unused fragments
# frags
Number of unused non-block fragments
# blocks
Number of unused full blocks
% fragmentation
Percentage of fragmentation, where: free fragments x 100 / total fragments in the file system
For information about fragments, see Fragment Size.
