System Administration Guide: Basic Administration
Package Requirements for Solaris Patch Management Tools (smpatch)
When you install the patch management tools, which is the smpatch command, several Solaris packages are added to your system, including some Java packages, that are required for the tools to run. In addition, several packages must be installed on your system before you can install the patch tools. These packages are as follows:
For information on verifying whether the required Solaris packages are installed on your system, see How to Verify Package Requirements for Signed Patch Tools (smpatch).
