System Administration Guide: Basic Administration
Examples—Downloading and Adding a Signed Patch (smpatch)
The following example shows how to download and add a signed patch with the smpatch command on a Solaris 9 system.
# /usr/sadm/bin/smpatch download -i 111711-01
Authenticating as user: root
Type /? for help, pressing <enter> accepts the default denoted by [ ]
Please enter a string value for: password :: xxx
Loading Tool: com.sun.admin.patchmgr.cli.PatchMgrCli from starbug
Login to starbug as user root was successful.
Download of com.sun.admin.patchmgr.cli.PatchMgrCli from starbug was
successful.
        Requested patches:
                111711-01
        Downloading the requested patches ...
For downloaded patch(es) see /var/sadm/spool.
# smpatch add -i 111711-01
successful.
        On machine starbug ...
                Installing patch 111711-01
The following example shows how to download and add patch 105081–45 with the smpatch command on a Solaris 2.6 system.
# smpatch download -i 105407-01
Requested patches:
    105407-01
/var/sadm/spool/105407-01.jar has been validated.
# smpatch add -i 105407-01
On machine "earth/172.20.27.27" ...
Installing patch 105407-01 ...
Purging /var/sadm/spool/105407-01
/var/sadm/spool/README.txt has been moved to
/var/sadm/spool/patchproSequester
The following example shows how to download and add patch 107081–45 with the smpatch command on a Solaris 7 system. This patch has two patch dependencies, which are automatically downloaded and verified.
# smpatch download -i 107081-45
Requested patches:
    107081-45
The following patches were added due to patch dependencies:
    108376-37
    107656-09
/var/sadm/spool/108376-37.jar has been validated.
/var/sadm/spool/107656-09.jar has been validated.
/var/sadm/spool/107081-45.jar has been validated.
# smpatch add -i 108376-37 -i 107656-09 -i 107081-45
On machine "venus/172.20.27.26" ...
Installing patch 108376-37 ...
Installing patch 107656-09 ...
Installing patch 107081-45 ...
Purging /var/sadm/spool/108376-37
Purging /var/sadm/spool/107656-09
Purging /var/sadm/spool/107081-45
The following example shows how to use the ftp command to get a signed Solaris 8 patch from the SunSolve Online web site and then use the smpatch add command to add the signed patch to the system.
# ftp sunsolve.sun.com
Connected to sunsolve.sun.com.
220-
220-Welcome to the SunSolve Online FTP server.
220-
220-Public users may log in as anonymous.
Name (sunsolve.sun.com:root): anonymous
331 Guest login ok, send your complete e-mail address as password.
Password: xxx
230-
230-SUN MICROSYSTEMS, INC.
.230 Guest login ok, access restrictions apply.
ftp> cd signed_patches
250 CWD command successful.
ftp> get 112846-01.jar /var/sadm/spool/112846-01.jar
200 PORT command successful.
150 Opening ASCII mode data connection for 112846-01.jar (22524 bytes).
226 Transfer complete.
local: /var/sadm/spool/112846-01 remote: 112846-01.jar
22613 bytes received in 0.065 seconds (341.70 Kbytes/s)
ftp> quit
# smpatch add -i 112846-01
Installing patch 112846-01 ...
Purging /var/sadm/spool/112846-01
