Using Sun's Certificates to Verify Signed Packages and Patches
A stream-formatted
SVR4–signed package or patch contains an embedded PEM-encoded PKCS7
signature. This signature contains at a minimum the encrypted digest of the
package or patch, along with the signer's X.509 public key certificate. The
package or patch can also contain a certificate chain
that is used to form a chain of trust from the signer's certificate to a locally
stored trusted certificate.
The PEM-encoded PKCS7 signature is used to verify the following:
The package came from the entity that signed it.
The entity indeed signed it.
The package hasn't been modified since the entity signed it.
The entity that signed it is a trusted entity.
The following table describes the encryption terminology associated
with signed packages and patches.
Term
Definition
ASN.1
Abstract Syntax Notation 1 (ASN.1) is a way to express a set of abstract objects.
For example, ASN.1 defines a public key certificate, all of the objects that
make up the certificate, and the order in which the objects are collected.
However, ASN.1 does not specify how the objects are serialized for storage
or transmission.
base64
base64 is a method of encoding arbitrary binary data as ASCII text.
DER
Distinguished Encoding Rules (DER) is a binary representation of an ASN.1
object. DER defines how an ASN.1 object is serialized for storage or transmission
in computing environments.
PEM
The Privacy Enhanced Message
(PEM) is a way to encode a file (in DER or other binary format) using base64
encoding and some optional headers. Initially used for encoding MIME-type
email messages. PEM is also used extensively for encoding certificates and
private keys into a file that exists on a file system or in an email message.
PKCS7
The Public Key Cryptography
Standard #7 (PKCS7) describes a general syntax for data that may have cryptography
applied to it, such as digital signatures and digital envelopes.
X.509
The International Telecommunication Union-Telcom (ITU-T) recommendation X.509
specifies the widely adopted X.509 public key certificate syntax.
This recommendation defines a framework for the provision of
authentication services. X.509 describes two levels of authentication:
Simple authentication – using a password as a verification
of claimed identity.
Strong authentication – involving credentials formed
using cryptographic techniques. While simple authentication offers some limited
protection against unauthorized access, use only strong authentication as
the basis for providing secure services.
Digital certificates, issued and authenticated by Sun Microsystems,
are used to verify that the downloaded package or patch with the digital signature
has not been compromised. These certificates are imported into your system's
keystore.
All Sun certificates are issued by Baltimore Technologies, which recently
bought GTE CyberTrust.
Access to a keystore is protected by a special password that you specify
when you import the Sun certificates into your system's keystore.
If you use the pkgadm listcert command, you can view
information about your locally stored certificates in the package keystore.
For example:
# pkgadm listcert -P pass:store-pass
Keystore Alias: GTE CyberTrust Root
Common Name: GTE CyberTrust Root
Certificate Type: Trusted Certificate
Issuer Common Name: GTE CyberTrust Root
Validity Dates: <Feb 23 23:01:00 1996 GMT> - <Feb 23 23:59:00 2006 GMT>
MD5 Fingerprint: C4:D7:F0:B2:A3:C5:7D:61:67:F0:04:CD:43:D3:BA:58
SHA1 Fingerprint: 90:DE:DE:9E:4C:4E:9F:6F:D8:86:17:57:9D:D3:91:BC:65:A6...
The following table describes the output of the pkgadm listcert command.
Field
Description
Keystore Alias
When you retrieve
certificates for printing, signing, or removing, this name must be used to
reference the certificate.
Common Name
The common name of
the certificate. For trusted certificates, this name is the same as the keystore
alias.
Certificate Type
Can be one of
two types:
Trusted Certificate - A certificate that can be used as a
trust anchor when verifying other certificates. No private key is associated
with a trusted certificate.
Signing Certificate - A certificate that can be used when
signing a package or patch. A private key is associated with a signing certificate.
Issuer Common Name
The name of the entity that issued, and therefore
signed, this certificate. For trusted certificate authority (CA) certificates,
the issuer common name and common name are the same.
Validity Dates
A date range that
identifies when the certificate is valid.
MD5 Fingerprint
An MD5 digest of the certificate. This digest can
be used to verify that the certificate has not been altered during transmission
from the source of the certificate.
SHA1 Fingerprint
Similar to an MD5 Fingerprint, except that it is
calculated using a different algorithm.
Each certificate is authenticated by comparing its MD5 and SHA1 hashes,
also called fingerprints, against the known correct fingerprints
published by the issuer.
