The following example identifies the steps to add the group mechanoids (group ID 101) to the system starbug. This example assumes that the launcher has been started and Users tool is open.
You can add existing users to the group when you add the group. Or, you can just add the group and then add the user to the group when you add the user.
Select Add Group from the Action menu.
Identify the group name, mechaniods, at the Group Name prompt under Group Identification.
Identify the group number, 101, at the Group ID number prompt.
Click on OK.
