Look in the following
files:
~/.dt/errorlog
~/.dt/errorlog.old
~/.dt/errorlog.older
~/.dt/sessionlogs
You can also try running the application from a command
line to see if any error message appear.
You can capture a core
file from a GNOME-compliant application by running the application with the --disable-crash-dialog option or by setting the GNOME_DISABLE_CRASH_DIALOG environment variable to 1 before running the
application.
