GNOME 2.0 Desktop for the Solaris Operating Environment Troubleshooting Guide
4.6 Nautilus Crashes Or Freezes
Problem
Nautilus crashes or freezes when an open browser window points to a bad NFS mount.
Solution
Run the following command: pkill nautilus
When Nautilus restarts, the bad NFS directory is not available. If you saved a session while Nautilus was pointing to a bad mount, remove your session files in ~/.dt/sessions/gnome.
