GNOME 2.0 Desktop for the Solaris Operating Environment Troubleshooting Guide
1.3 Uninstalling the GNOME 1.4 Desktop
Problem
I already have the GNOME 1.4 Desktop on system. How do I uninstall the GNOME 1.4 Desktop?
Solution
Perform the following steps:
  1. Log into CDE as root.
  2. Open a terminal window.
  3. Type cd /var/sadm/prod
  4. Type java uninstall_gnome_1_4
If you have already installed the GNOME 2.0 Desktop, you can remove the GNOME 1.4 Desktop by logging in as root and running the following command: /usr/sbin/remove-gnome -version 1.4
