Chapter 9 Localization and Internationalization Problems
This section provides information about how to deal with localization-
and internationalization-related problems in the GNOME 2.0 Desktop.
9.1 Localized Locales
Note – Arabic and Hebrew are not fully supported locales.
The GNOME 2.0 Desktop supports the locales listed in the following table.
Language
Locale
Arabic
ar
ar_EG.UTF-8
Brazilian Portuguese
pt_BR.ISO8859-1
pt_BR.UTF-8
Chinese, Simplified
zh
zh.GBK
zh.UTF-8
zh_CN.EUC
zh_CN.GB18030
zh_CN.GBK
zh_CN.UTF-8
Chinese, Traditional
zh_HK.BIG5HK
zh_HK.UTF-8
zh_TW
zh_TW.BIG5
zh_TW.EUC
zh_TW.UTF-8
English
Posix (C)
en_AU.ISO8859-1
en_CA.ISO8859-1
en_GB.ISO8859-1
en_GB.ISO8859-15
en_IE.ISO8859-1
en_IE.ISO8859-15
en_NZ.ISO8859-1
en_US.ISO8859-1
en_US.ISO8859-15
en_US.UTF-8
French
fr_FR.ISO8859-1
fr_FR.ISO8859-15
fr_FR.UTF-8
German
de_DE.ISO8859-1
de_DE.ISO8859-15
de_DE.UTF-8
Hebrew
he
he_IL.UTF-8
Italian
it_IT.ISO8859-1
it_IT.ISO8859-15
it_IT.UTF-8
Japanese
ja
ja_JP.eucJP
ja_JP.PCK
ja_JP.UTF-8
Korean
ko
ko_KR.EUC
ko.UTF-8
ko_KR.UTF-8
Polish
pl_PL.ISO8859-2
pl_PL.UTF-8
Russian
ru_RU.ANSI1251
ru_RU.ISO8859-5
ru_RU.KOI8-R
ru_RU.UTF-8
Spanish
es_ES.ISO8859-1
es_ES.ISO8859-15
es_ES.UTF-8
Swedish
sv_SE.ISO8859-1
sv_SE.ISO8859-15
sv_SE.UTF-8
Note – Some locales provide limited support, as follows:
9.2 Problems That Affect All Locales
The following problems affect all locales:
9.2.1 Unlocalized Menu Items
Problem
Affects all locales.
The following menu items are unlocalized across all locales:
Audio Control
Media Player
Solution
This problem will be
fixed in a future release.
9.2.2 Warning Messages to Console
Problem
Bug ID 4818711, affects
all locales.
When you launch GNOME applications from a terminal,
you might occasionally see warning messages in the terminal window.
Solution
These warnings do not
appear if you launch applications from the desktop environment menus. These
warnings do not affect the functionality of the application.
This bug will be fixed in a future release of the GNOME Desktop.
9.2.3 Obsolete Topics In Online Help
Problem
Obsolete applications such as gweather
and Stock Ticker are included in online Help.
Solution
Ignore Help for obsolete
applications.
9.2.4 Multiple Trash Icons
Problem
When you switch languages using dtlogin ,
and you log in remotely, multiple Trash icons are shown
on the desktop.
Solution
Perform the following
steps:
9.2.5 Dialogs and Panels Are Not Localized
Problem
A number of applications display unlocalized dialogs and panels.
Solution
9.2.6 Cannot Open a File Created in a Different Locale
Problem
Bug ID 4824884, affects
all locales.
Nautilus may not open a file that was created in
a different locale.
Solution
Log in to the locale
in which the file was created, then open the file.
9.2.7 Launching gmines Causes a Segmentation Fault
Problem
Affects the gmines game in all locales.
If you install a language
package, then gmines causes a segmentation fault
the next time you try to launch the game.
Solution
Remove the following
file to stop the game from freezing: /usr/share/locale/[your-locale]/LC_MESSAGES/gnome-games.mo.
This action also removes the localization support
for all games.
This problem will be fixed in a future release.
9.3 Problems That Affect European Locales
The following problems affect European locales:
9.3.1 OpenWindows Login Option Is Missing
Problem
Affects all European
locales in the Solaris 8 operating environment. This is not a problem for
the Solaris 9 operatinig environment.
When you install the GNOME
2.0 Desktop you might notice that OpenWindows is no longer present as a session
option in the login screen.
Solution
steps to restore the OpenWindows option to the login screen:
Log in as root.
Run the following command:
cp /usr/dt/config/C/Xresources.d/Xresources.ow /usr/dt/config/locale/Xresources.d/Xresources.ow
Where locale corresponds to
the locale for which you wish to restore the OpenWindows login option.
9.3.2 Start Menu Is Not Localized
Problem
Affects the pt_BR.ISO8859-1
locale.
The Start menu is not localized.
Solution
9.3.3 Characters Are Displayed Incorrectly in the XScreenSaver Properties
Dialog
Problem
and pt_BR.UTF-8 locales.
In the XScreenSaver Properties dialog, localization characters are missing, In the pt_BR.UTF-8
locale incorrect characters are displayed, for example Cryllic characters.
Solution
9.3.4 Keyboard Shortcut Does Not Change Input Method Window
Problem
Affects Russian locales.
The keyboard shortcut Ctrl+Spacebar to select and change the input method window does not work on the
x86 architecture edition of the Solaris operating environment.
Solution
Use the mouse to select
and change the input method window.
9.3.5 Poor Font Quality in Terminal
Problem
The font quality is low for the Terminal
application.
Solution
steps:
Open a terminal, then choose Edit -> Profiles.
Click on the Edit icon.
In the General tabbed section, deselect
the check box Use the same font as other applications.
Click on the font selection bar.
Choose a suitable font from the Choose a terminal
font dialog.
9.3.6 No Support for CP1251 and ANSI1251 Encoding
Problem
The pango X11 shaper in this release of the GNOME Desktop does
not support CP1251 encoding. As a result, CP1251 or ANSI1251 encoded characters
are displayed as zero-width or blank characters.
Solution
Use the following locales,
which are supported by the pango X11 shaper, until CP1251 support is available:
ru_RU.KOI8-R
ru_RU.ISO8859-5
ru_RU.UTF-8
You can use iconv conversion tables to re-encode CP1251
and ANSI1251 files. To encode a CP1251 or ANSI1251 file into a UTF-8 encoded
file, in a terminal run the following command:
/usr/bin/iconv
-f CP1251 -t UTF-8 CP1251 filename > UTF-8 filename. (man iconv)
9.3.7 Rasterization Problems in Russian Locale
Problem
Affects the ru_RU.KOI8-R
locale.
In the Solaris 8 operating environment, x86 architecture
edition, you might experience rasterization problems regarding the following
Russian glyphs:
This problem affects both the Common Desktop Environment
(CDE) and the GNOME Desktop.
Solution
You need to select
specific fonts for use within the GNOME Desktop. Perform the following steps:
Open a terminal and run the following command:
gnome-font-properties
Click on the Desktop font button in the Font Preferences dialog.
In the Pick a Font dialog, specify a
font from the following list:
application: medium, medium italic, bold, bold italic
arial: italic, bold, bold-italic
courier: italic, bold italic
fixed: medium
interface system: medium
monospace: normal
sans: italic, bold italic
times: italic, bold italic
9.3.8 Help Appears Only in English
Problem
Bug id 4921134, affects
the following locales:
fr_BE.UTF-8
es_AR.ISO8859-1
es_BO.ISO8859-1
es_CL.ISO8859-1
es_CO.ISO8859-1
es_CR.ISO8859-1
es_EC.ISO8859-1
es_GT.ISO8859-1
es_MX.ISO8859-1
es_NI.ISO8859-1
es_PA.ISO8859-1
es_PE.ISO8859-1
es_PY.ISO8859-1
es_SV.ISO8859-1
es_UY.ISO8859-1
es_VE.ISO8859-1
Solution
actions to resolve this issue:
Applications should now appear in the target locale.
9.4 Problems That Affect Asian Locales
The following problems affect Asian locales:
9.4.1 Default Desktop Font Is Too Small Or Blank
Problem
For example: bug ID
4805328, affects some locales, including Chinese locales.
Currently,
you cannot set the default font for the GNOME Desktop for each locale. As
a result, particularly if you are switching between locales, you might find
that the default desktop font is either too small or is rendered blank.
Solution
To change the default
desktop font, perform the following steps:
Use the Font Preferences dialog to change
font size to appropriate values. For example, in Chinese locales, you can
set both Application font and Desktop font to Sans 13.
9.4.2 Special Fonts Are Missing in Chinese Locales
Problem
Bug ID 4821955, affects
Traditional Chinese locales.
You cannot see the characters displayed
with some special fonts such as bold fonts. As a result, some characters in
the Yelp window appear to be missing.
Solution
You must change the pangox.alias file in /etc/{zh_TW.EUC,zh_TW.BIG5,zh_TW.UTF-8,zh_HK.BIG5HK,zh_HK.UTF-8}. Perform the following steps:
Log in as root.
Change to the directory where thepangox.alias
file is located for your locale. For example, for the zh_TW.BIG5 locale,
cd /etc/pango/zh_TW.BIG5
cat pangox.alias | tr [A-Z] [a-z] > /tmp/pango
mv /tmp/pango pangox.alias
If the directory /etc/pango/sparcv9/pango
is on your system, change the pangox.alias files. in
the locale subdirectories in that directory, in the same way as for /etc/pango.
9.4.3 GNOME Ghostscript Display
Problem
Affects Asian and Japanese
locales.
Characters with the Japanese Postscript font name are
garbled when displayed in GNOME Ghostscript.
Solution
steps:
Log in as root.
Run the following command: cd /
Run the following command: mkdir /Resource
Depending on the locale, run one of the following commands:
Simplified Chinese
ln -s /usr/openwin/lib/locale/zh/X11/Resource/CMap /Resource/CMap
Traditional Chinese
ln -s /usr/openwin/lib/locale/zh_TW/X11/Resource/CMap /Resource/CMap
Japanese
ln -s /usr/openwin/lib/locale/ja/X11/Resource/CMap /Resource/CMap
Korean
ln -s /usr/openwin/lib/locale/ko/X11/Resource/CMap /Resource/CMap
9.4.4 Different Date Format in the Solaris Operating Environment
Problem
Affects Japanese locales.
The date format is different in the Solaris operating environment.
There is no '(' and ')' on the weekday format in the following locales:
Solaris 8 operating environment: ja_JP.UTF-8
Solaris 9 operating environment: ja_JP.eucJP, ja_JP.UTF-8
Solution
Not applicable.
9.4.5 Character Display Problem in GTK2+ Applications
Problem
Bug ID 4785550, affects
the gedit application and other GTK2+ applications in Japanese locales.
Part of the IBM/NEC
extended character and special characters are not displayed.
Solution
Known limitation.
9.4.6 Printing Out From gedit in the Solaris 8 Operating Environment
Problem
You can preview JISX0212 in the gedit
application, but you cannot print out JISX0212.
Solution
Solaris 8 operating
environment: Known limitation.
Open the gedit application.
Choose Edit -> Preferences.
Select Fonts from the Print category, in the Categories panel.
For each print item, specify either of the following fonts:
HG-GothicB-Sun
HG-MinchoL-Sun
9.4.7 Cannot Print Japanese Characters With Default Font in gedit
Problem
Bug 4861491, affects
Japanese locales.
When you use the default printer font in the gedit application, Japanese characters are not displayed in
Print Preview and are not printed by printers.
Solution
steps:
For each print item, specify the HG-GothicB-Sun font.
9.4.8 Cannot Open ISO–2022–JP Encoded File
Problem
Bug ID 4826184, affects
Japanese locales.
You cannot open ISO-2022–JP encoded files
in the gedit application.
Solution
9.4.9 Localized Characters Do Not Display in gedit
Problem
For example: bug ID
4785550, affects Japanese locales.
Japanese characters do not
display in the gedit application, when you select
Courier as the default font.
Solution
steps:
Select Font & Colors in the Categories
panel.
Select the option Use default theme font.
This solution does not fix the problem that IBC/NEC extended
character and special characters are not displayed in the Solaris 8 operating
environment.
9.4.10 Character Display Problem in Terminal
Problem
In the Terminal application Preferences dialog, IBM/NEC extended character and special characters
are not displayed when you select the option Use the same font as
other applications.
Solution
steps:
Open a terminal.
Choose Edit -> Current
Profiles.
In the Editing Profiles dialog, deselect
the option Use the same font as other applications.
Specify the font to be interface user.
9.4.11 Core Dump When Copy or Link to File
Problem
Japanese locales.
A core dump sometimes occurs when you use Nautilus
to copy or link to a file that was created in a different locale.
Solution
in which the file was created, then copy the file or create a link to the
file.
9.4.12 Input Method Window Repeatedly Flushed
Problem
Bug ID 4781611, affects
the ja_JP.UTF–8 locale.
When there are multiple input contexts
on the same top-level application window, the input method window is repeatedly
flushed.
Solution
9.4.13 Japanese Locale Core Dump
Problem
Bug ID 4808468, affects
An application core dump occurs
when you do the following:
Choose Unicode List -> HIRAGANA from the IM status.
Close the application window.
Solution
9.4.14 GTK2+ Applications Freeze
Problem
Bug ID 4820426, affects
GTK2+ applications freeze when you
do the following:
Open a Lookup Choice window.
Press and hold the space key.
Solution
9.5 Problems That Affect Complex-Text Locales
The following problems affect complex—text locales:
9.5.1 Incomplete Support for Right-to-Left Languages
Problem
Affects Arabic and Hebrew.
Only partial support is available in the GNOME Desktop for right-to-left
languages. Full support for right-to-left language printing and GUI widget
mirroring is currently under development in the GNOME Desktop.
Solution
Arabic and Hebrew text
input is supported in the GNOME 2.0 globalization release, with the exception
of the Terminal application. If you have not installed
any other language pack, and you want text input support, then install the
following patches:
SPARC Architecture Edition
x86 Architecture Edition
Solaris 8 Operating
Environment:
114485-01
114486-01
Solaris 9 Operating
Environment:
114274-02
114275-02
