In the Terminal application Preferences dialog, IBM/NEC extended character and special characters
are not displayed when you select the option Use the same font as
other applications.
Solution
Perform the following
steps:
Open a terminal.
Choose Edit -> Current
Profiles.
In the Editing Profiles dialog, deselect
the option Use the same font as other applications.
