Solaris 9 9/04 Installation Guide
SPARC: Task Map: Setting Up a System for a Custom JumpStart Installation
During a custom JumpStart installation, the JumpStart program attempts to match the system that is being installed to the rules in the rules.ok file. The JumpStart program reads the rules from the first rule through the last. A match occurs when the system that is being installed matches all the system attributes that are defined in the rule. As soon as a system matches a rule, the JumpStart program stops reading the rules.ok file and begins to install the system, based on the matched rule's profile.
Table 29–1 Task Map: Setting Up a System for a Custom JumpStart Installation
Task
Description
For Instructions
Check if the system is supported
Check the hardware documentation for system support in the Solaris 9 environment.
Solaris 9 Sun Hardware Platform Guide
Check if the system has enough disk space for the Solaris 9 software
Verify that you have planned enough space to install the Solaris software on your system.
Chapter 5, System Requirements and Guidelines (Planning)
(Optional) Preconfigure system configuration information
You can use the sysidcfg file or the name service to preconfigure installation information for a system. If you preconfigure system information, the installation program does not prompt you to supply the information during the installation.
Chapter 7, Preconfiguring System Configuration Information (Tasks)
Prepare the system for custom JumpStart installation
Create and validate a rules file and profile files.
Chapter 26, Preparing Custom JumpStart Installations (Tasks)
(Optional) Prepare optional custom JumpStart features
If you are using begin scripts, finish scripts, or other optional features, prepare the scripts or files.
Chapter 27, Using Optional Custom JumpStart Features (Tasks) and Chapter 28, Creating Custom Rule and Probe Keywords (Tasks)
(Optional) Set up the system to install over the network
To install a system from a remote Solaris DVD or Solaris Software SPARC Platform Edition CD image, you need to set up the system to boot and install from an install server or a boot server.
Chapter 15, Preparing to Install From the Network With CD Media (Tasks)
(Optional) Prepare for a Solaris Flash archive installation
Before installing a Solaris Flash archive, you need to follow specific steps.
To Prepare to Install a Solaris Flash Archive With a Custom JumpStart Installation
Install or upgrade
Boot the system to initiate the installation or upgrade.
SPARC: To Perform an Installation or Upgrade With the Custom JumpStart Program
