This section provides instructions for creating, preparing, and performing custom JumpStart installations.
Provides an introduction and overview of the custom JumpStart installation method. |
Chapter 26, Preparing Custom JumpStart Installations (Tasks) |
Provides instructions about how to prepare the systems at your site from which and on which you are installing the Solaris 9 software with the custom JumpStart installation method. |
Chapter 27, Using Optional Custom JumpStart Features (Tasks) |
Describes the optional features that you can use to create additional tools for a custom JumpStart installation. |
Provides information and procedures for creating your own custom rule and custom probe keywords. |
Chapter 29, Performing a Custom JumpStart Installation (Tasks) |
Describes how to perform a custom JumpStart installation on a SPARC based or an x86 based system. You need to follow these procedures on the system on which you intend to install the Solaris 9 software. |
Provides an example of setting up and installing Solaris software on both SPARC based and x86 based systems by using the custom JumpStart installation method. |
Contains lists of keywords and values to be used in the rules file, profiles, begin scripts, and finish scripts. |
