Solaris 9 9/04 Installation Guide
To Display the Status of All Boot Environments (Command-Line Interface)
  1. Log in as superuser.
  2. Type:
    # lustatus BE_name
    BE_name
    Specifies the name of the inactive boot environment to view status. If BE_name is omitted, lustatus displays status for all boot environments in the system.
    In this example, the status for all boot environments is displayed.
    # lustatus second_disk
    boot environment   Is        Active  Active     Can	    Copy
    Name               Complete  Now	 OnReboot   Delete	 Status
    disk_a_S7           yes       yes     yes        no       -
    disk_b_S7database   yes       no      no         yes      COPYING
    disk_b_S8           no        no      no         yes      -
    Note –
    You could not perform copy, rename, or upgrade operations on disk_b_S8 because it is not complete, nor on disk_b_S7database because a live upgrade operation is in progress.
