Solaris 9 9/04 Installation Guide
To Install a Solaris Flash Archive With a Profile Keyword (Command-Line Interface)
This procedure enables you to install a Solaris Flash archive and use the archive_location keyword at the command line rather than from a profile file. You can quickly retrieve an archive without the use of a profile file.
  1. Log in as superuser.
  2. Type:
    # luupgrade -f -n BE_name -s os_image_path -J 'profile'
    -f
    Indicates to upgrade an operating system from a Solaris Flash archive.
    -n BE_name
    Specifies the name of the boot environment that is to be upgraded.
    -s os_image_path
    Specifies the path name of a directory that contains an operating system image. This directory can be on an installation medium, such as a DVD-ROM, CD-ROM, or it can be an NFS or UFS directory.
    -J 'profile'
    Specifies the archive_location profile keyword. For the keyword values, see archive_location Keyword.
    The boot environment is ready to be activated.
    Example 36–9 Installing a Solaris Flash Archive By Using a Profile Keyword (Command-Line Interface)
    In this example, an archive is installed on the second_disk boot environment. The -J option and the archive_location keyword is used to retrieve the archive. All files are overwritten on second_disk except shareable files.
    # luupgrade -f -n second_disk \
    -s /net/installmachine/export/solarisX/OS_image \
    -J 'archive_location http://example.com/myflash.flar'
