Solaris 9 9/04 Installation Guide
Sample Layout for Mirrored File Systems
The following figure shows a mirror that duplicates the root file system (/) over two physical disks. State database replicas (metadbs) are placed on both disks.
Figure 10–2 Sample Layout for a Mirrored Root File System
The context describes the illustration.
Figure 10–2 shows a system with the following configuration.
For an example profile that uses the custom JumpStart installation method to create this configuration, see Example 26–10.
For instructions on how to create mirrored file systems with Solaris Live Upgrade, see To Create a Boot Environment With RAID-1 Volumes (Mirrors) (Command-Line Interface).
