Solaris 9 9/04 Installation Guide
Planning for a Network Installation Introduction
This section provides you with information you need before you can perform an installation from the network. Network installations enable you to install the Solaris software from a system, called an install server, that has access to the Solaris 9 disc images. You copy the contents of the Solaris 9 DVD or CD media to the install server's hard disk. Then, you can install the Solaris software from the network by using any of the Solaris installation methods.
Required Servers for Network Installation
To install the Solaris operating environment from the network, the systems to be installed require the following servers to be present on the network.
Figure 13–1 illustrates the servers that are typically used for network installation.
Figure 13–1 Network Installation Servers
This illustration depicts the servers that are typically used for network installation.
Using DHCP to Provide Network Installation Parameters
Dynamic Host Configuration Protocol (DHCP) provides the network parameters that are necessary for installation. When using DHCP, you do not need to create a separate boot server. After you have created the install server, you add clients to the network with the add_install_client command and the -d option. The -d option enables you to set up client systems for Solaris installation from the network by using DHCP.
For information on DHCP options for installation parameters, see Preconfiguring System Configuration Information With the DHCP Service (Tasks).
