Solaris 9 9/04 Installation Guide
Installing Software With Web Start Installation Programs With Finish Scripts
You can use finish scripts to install additional software after the Solaris operating environment is installed. Some software programs are installed by the Solaris Web Start program, which prompts you to enter information during the installation. To maintain a hands-off installation, you can run the Solaris Web Start program with the -nodisplay or -noconsole options.
Table 27–1 Solaris Web Start Options
Option
Description
-nodisplay
Runs the installer without a graphic user interface. Use the default product installation unless the installation was modified by the -locales option.
-noconsole
Runs the installation without any interactive text console device. Useful when paired with -nodisplay for UNIX script use.
For more information, see the man page installer(1M).
