Solaris 9 9/04 Installation Guide
SPARC: Disk Configuration File Example
The following example shows how to create a single–disk configuration file, 104_test, on a SPARC system with a 104-Mbyte disk.
Example 27–7 SPARC: Creating a Disk Configuration File
You redirect the output of the prtvtoc command to a single–disk configuration file that is named 104_test:
# prtvtoc /dev/rdsk/c0t3d0s2 >104_test
The contents of the 104_test file resemble the following:
* /dev/rdsk/c0t3d0s2 partition map
* Dimensions:
*     512 bytes/sector
*      72 sectors/track
*      14 tracks/cylinder
*    1008 sectors/cylinder
*    2038 cylinders*    2036 accessible cylinders
* Flags:
*   1: unmountable
*  10: read-only
*                          First     Sector    Last
* Partition  Tag  Flags    Sector     Count    Sector  Mount Directory
       1      2    00          0     164304   164303   /
       2      5    00          0    2052288  2052287
       3      0    00     164304     823536   987839   /disk2/b298
       5      0    00     987840     614880  1602719   /install/298/sparc/work
       7      0    00    1602720     449568  2052287   /space
You have created disk configuration files for a SPARC based system. Testing a Profile contains information about using disk configuration files to test profiles.
