Solaris 9 9/04 Installation Guide
Upgrading (Overview)
An upgrade merges the new version of the Solaris operating environment with the existing files on the system's disk. An upgrade saves as many modifications as possible that you have made to the previous version of the Solaris operating environment.
You can upgrade any system that is running the Solaris 2.6, Solaris 7, or Solaris 8. Type the following command to see the version of Solaris software that is running on your system:
$ uname -a
You can upgrade the Solaris operating environment by using the following installation methods.
Note –
Use the smosservice patch to upgrade diskless clients. For detailed instructions, refer to System Administration Guide: Basic Administration or to smosservice(1M).
If you are already running the Solaris 9 operating environment and have installed individual patches, upgrading to a Solaris 9 Update release causes the following:
You can use the Patch Analyzer to determine which patches, if any, will be removed by upgrading to the Solaris 9 Update release. For detailed instructions about using the Patch Analyzer, refer to Upgrading to a Solaris Update Release.
Solaris Upgrade Methods
Table 8–1 SPARC: Solaris Upgrade Methods
Platform
Current Solaris Operating Environment
SPARC systems
Solaris 2.6, Solaris 7, Solaris 8, Solaris 9
  • The Solaris Web Start program
  • Solaris suninstall program
  • Custom JumpStart method
  • Solaris Live Upgrade
Table 8–2 x86: Solaris Upgrade Methods
Solaris 2.6
Installing from DVD media or a net installation image:
  • Solaris Web Start program
Installing from CD media:
Solaris 7
Installing from DVD or CD media or a net installation image:
Note –
For limitations on upgrading using Solaris Live Upgrade, see Solaris Live Upgrade Requirements.
You cannot upgrade your system to a software group that is not installed on the system. For example, if you previously installed the End User Solaris Software Group on your system, you cannot use the upgrade option to upgrade to the Developer Solaris Software Group. However, during the upgrade you can add software to the system that is not part of the currently installed software group.
