Solaris 9 9/04 Installation Guide
Solaris suninstall Program
The Solaris suninstall program on the Solaris Software 1 of 2 CD is run with a command-line interface (CLI). The Solaris suninstall program guides you step-by-step through installing or upgrading to the Solaris 9 software. This installation method is good if you have insufficient memory to run a GUI and are running international locales.
The Solaris suninstall program only installs the Solaris operating environment software. This program does not know of third–party applications or network-downloadable software. You must install third–party applications after you have installed the Solaris operating environment. Also, you are prompted to enter system configuration information during installation, so suninstall is not the most efficient installation method for installing several systems. The Solaris Web Start program enables you to install third-party applications. Or, for batch installations of a large number of systems, use custom JumpStart or the Solaris Flash installation feature.
For detailed instructions, refer to Chapter 18, Using the Solaris suninstall Program (Tasks).
