You can configure multiple network interfaces in your sysidcfg file. For each interface that you want to configure, include a network_interface entry in the sysidcfg file.
You can use the network_interface keyword to configure multiple interfaces in the following ways.
With DHCP – You can use a DHCP server on your network to configure a network interface. For more information on how to use a DHCP server during your installation, see Preconfiguring System Configuration Information With the DHCP Service (Tasks).
To use the DHCP server to configure a network interface on the system, use the following syntax for the network_interface keyword.
network_interface=value {primary dhcp protocol_ipv6=yes-or-no} |
Instructs the installation program to configure a specific interface, such as hme0 or eri1.
(Optional) Specifies value as the primary interface.
Instructs the installation program to configure the system to either use IPv6 or to not use IPv6.
For WAN boot installations, you must set the value of protocol_ipv6=no.
Without DHCP – If you do not want to use DHCP to configure the network interface, you can specify the configuration information in the sysidcfg file. To instruct the installation program to configure multiple interfaces without using DHCP, use the following syntax.
network_interface=value {primary hostname=host_name default_route=ip_address ip_address=ip_address netmask=netmask protocol_ipv6=yes_or_no} |
(Optional) Specifies the host name of the system.
(Optional) Specifies the IP address of the default router. If you want the installation program to detect the router by using the ICMP router discovery protocol, omit this keyword.
If the installation program cannot detect the router, you are prompted for the router information during the installation.
(Optional) Specifies the IP address of the system.
(Optional) Specifies the netmask value for the system.
(Optional) Instructs the installation program to configure the system to either use IPv6 or to not use IPv6.
To perform an unattended custom JumpStart installation, you must specify a value for the protocol_ipv6 keyword.
Include any combination or none of the hostname, ip_address, and netmask keywords, as needed. If you do not use any of these keywords, omit the curly braces ({}).
In the same sysidcfg file, you can use DHCP to configure certain interfaces, while also specifying the configuration information for other interfaces in the sysidcfg file.
In the following example, the network interfaces eri0 and eri1 are configured in the following way.
eri0 is configured by using the DHCP server. IPv6 support is not enabled on eri0.
eri1 is the primary network interface. The host name is set to host1, and the IP address is set to 172.31.88.100. The netmask is set to 255.255.255.0. IPv6 support is not enabled on eri1.
network_interface=eri0 {dhcp protocol_ipv6=no} network_interface=eri1 {primary hostname=host1 ip_address=172.31.88.100 netmask=255.255.255.0 protocol_ipv6=no} |
