You can set the time zone for the system with the timezone keyword. Use the following syntax.
timezone=timezone |
In the previous example, timezone specifies the time zone value for the sytem. The directories and files in the /usr/share/lib/zoneinfo directory provide the valid time zone values. The timezone value is the name of the path relative to the /usr/share/lib/zoneinfo directory. You can also specify any valid Olson time zone.
In the following example, the system time zone is set to mountain standard time in the United States.
timezone=US/Mountain |
The installation program configures the system to use the time zone information in /usr/share/lib/zoneinfo/US/Mountain.
