Solaris 9 9/04 Installation Guide
Syntax Rules for the sysidcfg File
You can use two types of keywords in the sysidcfg file: independent and dependent. Dependent keywords are guaranteed to be unique only within independent keywords. A dependent keyword exists only when it is identified with its associated independent keyword.
In this example, name_service is the independent keyword, while domain_name and name_server are the dependent keywords:
name_service=NIS {domain_name=marquee.central.example.com
name_server=connor(192.168.112.3)}
Syntax Rule
Example
Independent keywords can be listed in any order.
pointer=MS-S
display=ati {size=15-inch}
Keywords are not case sensitive.
TIMEZONE=US/Central
terminal=sun-cmd
Enclose all dependent keywords in curly braces ({}) to tie them to their associated independent keyword.
name_service=NIS
You can optionally enclosed values in single (`) or double quotes (“).
network_interface='none'
For all keywords except the network_interface keyword, only one instance of a keyword is valid. However, if you specify the keyword more than once, only the first instance of the keyword is used.
name_service=NIS
name_service=DNS
