Solaris 9 9/04 Installation Guide
To Create a Temporary Solaris 9 Environment to Test a Profile
To test a profile for a particular Solaris release successfully and accurately, you must test a profile within the Solaris environment of the same release. For example, if you want to test a Solaris 9 initial installation profile, run the pfinstall command on a system that is running the Solaris 9 operating environment.
You need to create a temporary installation environment if you are testing a profile under one of the following conditions:
  1. Boot a system from an image of one of the following:
    • Solaris SPARC Platform Edition DVD
    • Solaris x86 Platform Edition DVD
    • Solaris Software 1 of 2 SPARC Platform Edition CD
    • Solaris Software 1 of 2 x86 Platform Edition CD
    Note –
    If you want to test an upgrade profile, boot the system that you are upgrading.
  2. Respond to the system identification questions.
  3. Exit from the installation program.
    • If you are using the Solaris DVD, type ! at the following prompt.
      Solaris Web Start will assist you in installing software for Solaris.
      <Press ENTER to continue> {"!" exits}
    • If you are using the Solaris Software 1 of 2 CD, select the Solaris suninstall program as the program to install the Solaris 9 operating environment. On the first screen that is displayed, select Exit.
  4. Execute the pfinstall command from the shell. For details about using the pfinstall command, see Step 7 in To Test a Profile.
